It is currently Wed Oct 14, 2026 21:22 pm
М:Mossin upgrades
Post new topic Reply to topic  [ 2 posts ]
 PostPosted: Sat Jan 07, 2017 16:08 pm
I.P.S.C. member
Привет
найдены в закромах штучки для усовершенствования мосинки али свт
Mosin Nagant, Tri Rail Mount, MNTR01 можно ставить вместо штатных 49EUR
Features of Leapers Tri Rail Mount:
•Precision Machined with Maximum Strength
•Extended Top Rail with 17 Slots for Flexible Eye Relief Adjustment, 2 Removable Side Rails with 12 Slots for Additional Accessories
•Features Innovative Double Locking System with Zero-Gap Tight Tolerance for Most Secure Fit
•Great Zero Retention Capability for All Accessories Installed on the Rails
•Includes 2 Steel Adaptors to Replace Rear Sight for Dual Use on Either Full Size or Carbine Rifles
•Intensively Tested by Field Experts and Demonstrates Most Satisfactory Performance
•Friendly Installation, No Gunsmithing Required
https://www.youtube.com/watch?v=OSjGDE_xjj8
Mosin Nagant M44 Bolt-On Muzzle Brake, Cal. 7.62*54R 35EUR
Mosin Nagant M44 Muzzle Brake - Bolt-On
Muzzle Brake bolts over the barrel and behind the Front Sight Post with a Muzzle Brake Half Ring
Ports of the Muzzle Brake redirects the propellant gasses upwards and to the sides, reducing the felt recoil
Steel Construction
Length: 3.9"
Mosin Nagant, Cal. 7.62*54, Rubber Extended Recoil Buttpad 36EUR
Pad takes some of the kick and sting out of your high-powered rifle shots
Non-slip rubber, one-inch thick device is compatible with all mosin nagant rifles
Reduces recoil by approximately 40%
Mounts easily using existing buttplate screws
+37256491009
 PostPosted: Wed Jan 18, 2017 17:10 pm
I.P.S.C. member
Muzzle Brake и Tri Rail проданы..
Users browsing this forum: No registered users and 48 guests
