It is currently Wed Oct 14, 2026 11:46 am
Продам оружейные шкафы на 5 и 6 единиц Metalk, Infac Safe
Post new topic Reply to topic  [ 1 post ]
 PostPosted: Fri Nov 03, 2017 15:11 pm
Продам оружейные шкафы Metalk (Италия) на 5 единиц, Infac Safe (Испания) на 6 единиц, внутри имеется запирающийся ящик для патронов
Цена 200 евро за шт (обычная цена 300+ евро)
Metalk (Италия) на 5 единиц, темно серые
высота 149,5 cm (внутренняя до ящика 130,5 cm), ширина 32 cm, глубина 29 cm
Metalk K series is built from an outer structure with a 2/3mm thick single piece steel piece. Door structure: a piece of 2/3 mm thick steel. Door thickness 50 mm. Locks with double-sided lock certified with EN1300. It secures with nickel-plated Ø 18/22 mm pins, three points forward, one top and one bottom. The door embraces the side along the door. With ready holes for safe wall and floor fixing. At the top there is a slot, locked with a different key.
Infac Safe (Испания) на 6 единиц, светло серые
высота 150,5 cm (внутренняя до ящика 130 cm), ширина 34,5 cm, глубина 32,5 и 25 cm
Infac 6 Gun Safe With Shelf – B6. This model can hold 6 pcs upright rifles or shotguns due and comes with a fixed, welded top shelf. Dimensions : Height 1500mm, Width 350mm, Depth 330mm and 250mm. Designed and produced in the EU from quality DD12 steel plate in 3mm thickness. Gunsafe door is double walled, reinforced with anti – pry protection and with fully protected door swivels. Door is locked through 5 side roll pins (25 mm diameter) with anti – jemmy protection and with recessed closing mechanism. Activated by a security lock with 6 blades and double map key. Painted in epoxy coated finish, oven fired at over 220ºC. Cabinets have holes predrilled at the back and bottom for secure fixing to a wall or floor.
Users browsing this forum: No registered users and 27 guests
