It is currently Mon Oct 19, 2026 12:14 pm
Glock 17 PRO
Post new topic Reply to topic  [ 8 posts ]
 PostPosted: Sun Feb 22, 2009 22:05 pm
Смотрите активней официальные рупоры ИПСЦ, дабы потом не было вопросов, почему данный Глок идет в стандарт.
Привожу переписку Дагниса с Пинто. Кто не знает ни того, ни другого, может поверить, что люди оба в теме, а кто знает, тот и не спросит:
Dagnis Maiberg
I hope my post will fit in the topic...
Anyway @Vince. I would like to see Glock 17-Pro Specifically either on the approved list or not approved list. Of course with regular 17 mags.
Current PD list seems to cause a lot of confusion in the northern part of the Europe.
And if it ends up now in the banned models list I would kindly like to know why.
Regards
Dagnis
Vince Pinto
We cannot list the "Pro" version, one way or the other, because (and please correct me if I'm wrong), it's not a factory designation, just like the so-called "Mambo" version of the SP-01 is not a factory designation.
In other words, we cannot list dealer or distributor designations.
Dagnis Maiberg
I had to call to Austria anyway. I will get back on that. Last time I called to Glock Austria they claimed that everything is done in factory and the model is Pro, just distributed for the northern market. Fin, Est maybe somewhere else as well.
And by the way who is designating names: 17A, 17DK?
Dagnis
Vince Pinto
Good question (and, God, I hate when that happens!)
Seriously though, I made a distinction between tags used only to identify longer barrels created by an OFM in order to comply with the laws of a country (e.g. 17A for Australia, 17DK for Denmark) versus a "custom" gun with various bits 'n' pieces, created by a dealer or distributor. Same argument for the "Mambo".
If this is really a problem, I can easily delete the "17A, 17DK, SP-01A, SP-01DK" tags on the list, because the rest of the wording still delivers the message:
"Also approved are variants with original <OFM name> barrels which are longer than standard, provided the barrel length does not exceed 127mm, and provided all other aspects of these variants fully comply with all other Production Division rules"
У кого еще есть вопросы и размахивания листами правил???
 PostPosted: Sun Feb 22, 2009 22:48 pm
Спасибо за информацию.
Для тех кто не владеет ингишом, могут воспользоваться переводчиком:
http://translate.google.com/translate_t ... en|ru|good
 PostPosted: Sun Feb 22, 2009 23:12 pm
Просто уже как дополнение любопытным и дотошным:
http://www.pistolnz.org.nz/pdf/section//profaq07.pdf
Винса тож достают нехило, раз пишет такое :mrgreen:
И его статус в иерархии: IPSC Secretary Mr. Vince Pinto
 PostPosted: Sun Mar 08, 2009 11:27 am
с удовольствием прочитал, но так и не понял Глок 17 (не глок про а обычный 17) с установленым на заводе удлинненым до 127 мм стволом(я подчеркиваю на заводе изготовителе, номер ствола и затвора совпадает), подходит под правило Also approved are variants with original Glock barrels which are longer than standard (e.g. 17A, 17DK), as well as variants with "Tactical", "Mariner" or similar OFM engravings on the slide, provided the barrel length does not exceed 127mm, and provided all other aspects of these variants fully comply with all other Production Division rules, которое по прежнему висит здесь http://www.ipsc.org/proddiv.php или нет. Потому что ситуация действительно дурацкая - вот они правила в Production Division List, но в данном вопросе мы правилами пользоваться не будем потому что.... да просто так. если честно вопрос не принципальный, в конце концов все это для удовольствия и не более. просто неприятно когда правила меняют в процессе игры
GSM 56984125
 PostPosted: Sun Mar 08, 2009 11:43 am
В правилах надо читать не только приложения, но еще и сами правила.
Раньше, в скобках, стоял и про и тогда он шел в продакшен. С нового года его убрали.
А правила говорят очень четко - только модели, ПЕРЕЧИСЛЕННЫЕ в приложении. Теперь найдите мне в разделе глока, что бы было конкретно - глок 17 про.
И еще одна просьба - штангель-циркулем промеряйте ствол плиз - от кончика до кончика и напишите сюда длинну. Тут уже чисто мой интерес :mrgreen:
 PostPosted: Sun Mar 08, 2009 11:50 am
штанельциркуля под рукой нет, но от кончика ствола до конца патронника 124 мм, до конца подающей рампы 127, доберусь до работы померяю штангель циркулем, тогда и десятые мм будут ясны
еще раз перемерял, вставил гильзу в патронник, 127мм получается вместе с той частью гильзы что не помещается в патронник и торчит снаружи
GSM 56984125
 PostPosted: Sun Mar 08, 2009 13:24 pm
17PRO был в листе продакшен. потом его убрали.
финны (откуда этот пистолет родом) утверждают, что ствол длинее 127 мм. вопрос в корректном методе измерения. прежде, чем хвататься за штанген, почитайте GV
 PostPosted: Sun Mar 08, 2009 15:11 pm
Виктор Суздальцев, проведя замер по всем правилам на своем Про получил результат: 128 мм.
Я склонен верить ему, т.к. он сам владелец Про и из-за этого перешел в стандарт, лишившись пистолета для продакшена в виду выкидывания данного глока из списка.
Далее споры можно прекратить только уже потому, что данный пистолет НЕ ЯВЛЯЕТСЯ ОРУЖИЕМ ПРОДАКШЕНА в виду кучи причин и в виду вполне конкретного заявленя секретаря ИПСЦ.
Любители глушителей могут оставить себе его для развлекухи, а желающим остаться в продакшене придется поменять пистолет или, как минимум, ствол
Users browsing this forum: No registered users and 25 guests
